V
vette-dude
If anyone has taken one of these off I need to know how the six sheetmetal screws on the sides for the upper to lower cover/shroud were mounted. Mine had the head facing the frame on both sides and it was next to impossible to get to with any kind of wrench or socket. My plan for re-assembly is to remove the clips on the upper shroud and put them on the lower shroud so I can re-attach by screwing in the sheetmetal screws from the air dam intake under the car. Otherwise how in the heck could you get the screws started and tightened with the limited space between frame and shroud? Maybe this was assembled wrong by former owner or someone at Bowling Green had their head in the wrong place when it was engineered. Could someone look and tell me? I also am thinking why Mid America or someone doesn't make a shroud with a plate or cover that removes from the top to suck out all the leaves and debris. It would be an easy fix to the problem. 94 C4 Coupe. Thanks.:duh
