This is my only mod . There is no Dyno rating , just E.T. improvement , I think they figure the H.P. rating by the E.T. with a math formula . I was told that max H.P. increase would be between 60 & 100 mph . I think for sure you would get the same increase as the rammer air system , K&N or other from idle to 60 mph . I did not want a big hole hole in the radiator shroud and it would not actually be ramming air in the air intake becauase the air is mainly going through the radiator as what is was design to do . I think putting any open filter system will give you better performance , I wanted it open to fresh air . I did a lot of research tring to find out what works the best , I won't do a MAF or throttle body or exhaust , maybe an air bridge or tube , spark plugs and wires and oil changes is all I plan on doing .
Thanks ,
Joe
Crank and Chrome did an K&N Filter system which includes the air bridge and gain 22 H.P. on the dyno , so I would think I would have that much with a bonus of ram air .
