Mike Zarnock
I have a 91 Coupe that will spark knock real bad when warm. When it does, the "Service Engine" light will come on. The car will loose power, like you have the break on. You have to pull over and stop. If you turn it off and restart it, the light will go off and it will run fine for a while. It will not throw a code when checked.
I have changed the fuel filter, ignition modual, plugs, cap, rotor and use the best fuel I can find. The advance is working fine when checked at all times.
The only thing I have not changed that I can think of is the coil. Could it be breaking down when it gets hot? Is there something I missed? Is this common?
I'm going nutz! I hate all this computer junk!!!!!
PLEASE HELP!!!!!
Mike
PLEASE HELP!!!!!
Mike
