rear axle ratio
regalniz
vegas baby vegas
94 Polo Green Convertible w/auto
ok. so i looked under my console and i see i have the performance axle ratio, G92. damned if i can find the actual ratio anywhere. my 91 was 3.07. is it the same?
Ken
Gone but not forgotten
Hermosa Beach, CA
1987 Z51 Silver Coupe
Yep. ;)
It also appears as though 1994 was the first year to have the G92 option available without restriction.
_ken :w
regalniz
vegas baby vegas
so how do i find out the actual ratio since chevy offered so many in 94. i can remember seeing tags on GM rear ends with the ratio stamped on.
Ken
Hermosa Beach, CA
I just looked in Mike Antonick's new book Cor- Vette Specs 1984-1996 and discover that although there is only one option code listed (G92), there are actually four different axles ratios that were available in 1994:
  • 2.59:1 ratio: 17 pinion teeth, 44 ring gear teeth, 7.875" ring gear outside diameter.
  • 3.07:1 ratio: 14 pinion teeth, 43 ring gear teeth, 7.875" ring gear outside diameter.
  • 3.33:1 ratio: 12 pinion teeth, 38 ring gear teeth, 8.5" ring gear outside diameter (manual trans).
  • 3.45:1 ratio: 11 pinion teeth, 44 ring gear teeth, 8.5" ring gear outside diameter (manual trans and ZR-1)
Learn something new every day, except what codes go along with those ratios. :L
_ken :w
Ken
Hermosa Beach, CA
:L I think I just answered my own question.
You didn't state if it was auto or manual trans, so if it's an auto, you've got 3.07:1 ratio as the perforrmance axle. If it's a manual, you have the 3.33:1 or the 3.45:1 ratio. ;)
_ken :w
regalniz
vegas baby vegas
sorry. its an auto. thats what i needed to know. thanx dude. while i got your attention, i need headers. no shortys. i wanna keep it legal so they need to have all emissions (cough!) already in place.
Ken
Hermosa Beach, CA
Oh you'll get a lot of response to the header question alright; everybody's got one... A "preference" that is. ;)
Mine happens to be long tube headers, and the smog nazis be damned! :L
Shop around at places like Jeg's or Summit in addition to the usual "Corvette's only" places. You'll find something that suits your needs.
_ken :w
S
Shadowing1985v
do headers do much when u have a auto tranny then for what it does for a stick
someone told me it does
plus i was told headers are only good for 350 hp plus
whats your guy's opionions(man i can't spell)
Edmond
Louisiana
2003 Z06
How in the world do I find out my gear ratio? I have a 88' 35th Anniversary coupe.
Thanks,
Ken
Hermosa Beach, CA
Edmond, you've been around here long enough to have seen us talking about the code list that can be found under the rear compartment lid or the console lid, and the also codes found on your build sheet or window sticker. Your code, if you have the performance axle ratio, would be found in one of those places. ;)
_ken :w
Radar
Oconomowoc, WI
1989 Medium Blue Metalic Convertible
I found out my axle ratio by reading the options card on the inside cover of the console lid. Then I looked the code up in my GM shop manual. The manual has a chart to decode the options code. My 89 vert with auto has the standard 2:59's.
Radar :)
Staten Island, NY
1999 Torch Red Coupe
Regalniz
Shorty headers are really performance manifolds at best. If a 10 to 12 hp improvement is worth an over $300 investment to you that go for it.
Long tubes are the real deal, you can call the tech line of any large header manufacturer to verify (hooker, headman, SLP).
Good luck
C
Cigarman
Radar :)
My 6-speed '89 has a 3.54 rear end. Any '89 made before Feb has that rear, after that the standard was 3.33. If you wanted the 3.54 after Feb, you had to special order it--I had understood that more '89 cars have the 3.33.
The 3.54 is coded GH0.
Wnat is your car's birthday?
