greggome
Active member
I have noticed an occasional rear end clunk when shifting gears, particularly 1st to 2nd especially if I let the clutch out quickly. If I ease out the clutch it helps eliminate the clunk. Sounds like its right rear but cant tell for sure. Thought it might behalf shaft U joints but I have read that they usually start squeaking which is a sound I have not noticed. Looked at the lower round rubber differential carrier to chassis cushion and it appears ok. U joints look like a job to replace. I hate to start tearing things apart that dont need it. Any other things that can cause that clunk that I can check?
