crackervette
The turn signals on my 76 quit working,so I changed the bulbs,flasher,no luck...got underneath and cleaned the ground drivers side rear...turn signals started working...turned headlights on...now both filaments in the drivers side bulb are burning...no turn signal on drivers side rear when headlights are on,and obviously no brake light(on all the time)...I'm guessing the only ground for the rear harness is the one I cleaned,and it is working fine...I took off the ground wire and the brake light filament went out...I don't know what to try next...I'd sure appreciate any and all suggestions...thanks!
