V
vetter1986
My 86 Vette rear pinion seal keeps leaking on the exhaust giving that burnt 80/90 smell. I have replaced the seal once already and it is leaking again. Whe n I replaced it the first time, I noticed the driveshaft ujoints were stiff. I replaced these also. This only lasted about 6 months and it is leaking again. There are no burrs on the yoke seal area and the pinoin bearings are smooth and are not loose. Has anyone else ran into this problem and if you have, what was done to correct it. Thanks in advance.
