oldmansvette
has anyone out there changed rear wheel bearing on there 81 vette? Sure could use some help.;help
...Sure could use some help...
Now if you need to rebuild them you have some options.
1-exchange. This is the fastest and maybe lower cost but I've seen and heard of arms exchanged that were in worse shape then the originals.Not the route I recommend~ of course others will disagree.
2- rebuild them yourself, if you have the tools, access to a surface grinder,and like to do your own go for it. It will cost more in most cases if you need to buy tools or sub out the machine work. NOTE: many rebuilders do not machine fit these so I would ask around. Me, I always machine fit every mating part that goes on the spindle. It's the only way I would do them but you will get various opinions on this as well.
3- I can link you to the write up I put together for this job that will help you decide if you want to tackle it or give you some idea on questions to ask.
Good luck,maybe it's just a dragging parking brake.
I would love to see this write up, tools arnt limited for me and i need to take off the spindle anyways. Thanks
