M
mmdog85
just finished the rebuild on 85 tpi engine l98. All went pretty good ,just a couple of bugs, hope you can help. stock rebuild except for flat top pistons,roller tip rockers and mild perfomance cam. I am having trouble with a surging idle. Im wondering if the cam could be the problem, the lift is 258 int and 280 exh with the lobe c/l at 104. Im wondering if this can give the idle problem, and if maybe a new chip can help. Im also getting a code 43 when I punch it and wonder if this may cause the idle surge . Any help is appreciated. thanks
