A
AUSSIEVETTEMAN
Hi guys,
Well the this will be the fourth time in 14 months we have had to adjust the Roller Rockers we installed onto the Vette.
We have replaced a set of Speed Pro hydraulic lifters at 8 months into the engine warranty time (12 months). The valve train has taken another 6 months to rattle up again.
I do not know what is out and have started to gather the specs of the cam, lifters and roller rockers.
The cam is a Speed Pro CS1013R Cam.
Push rods are standard GM, our old ones cleaned, tips are good.
Lifters are standard hydraulic - Speed Pro.
Roller Rockers are Yella Terra Steet Terra's ST2004 - 3/8" stud mount (1.6)
Inlet lift at valve is .443
Exhaust lift at valve is .465
SAE 288 degrees inlet and 298 exhaust
Any tips on what could be causing the premature failure of the lifters?
Cheers
Tony
Cheers
Tony
