- Moderator
- #21
- Joined
- Nov 9, 2000
- Messages
- 7,527
- Location
- Edgerton, Ohio, United States
- Corvette
- 1959 black 270hp (9/2/69) 1981 Beige L81(10/20/80)
I thought others would like to see the specs that Crane recommended.
Part Number:119831
Grind Number:HR-284-2S-12 IG
Engine Identification: Start Yr. End Yr. Make Cyl
1957 1987 CHEVROLET 8
Description
FAIR IDLE, MODERATE PERFORMANCE USAGE, GOOD MID-RANGE HP, MILD BRACKET RACING,
AUTO TRANS W/2500+ CONVERTER,
3000-3800 CRUISE RPM,
9.5 TO 10.75 COMPRESSION RATIO ADVISED.
BASIC RPM 2500-6000
Engine SizeConfiguration 262-400 C.I.V
Valve Setting:Intake.000Exhaust.000HOT
Lift:Intake @Cam339@Valve509
All Lifts are based on zero lash and theoretical rocker arm ratios.
Exhaust @ Cam352@Valve528
Rocker Arm Ratio1.50
Cam Timing:
TAPPET@.004Lift: OpensCloses ADV Duration Intake 31.0 BTDC73.0 ABDC284.0 ° Exhaust79.0 BBDC33.0 ATDC292.0 °
Spring Requirements: Triple Dual Outer Inner
Part Number99838
Loads:
Closed112LBS @1.650 or 1 21/32
Open313LBS @1.150
recommended RPM range with matching components:
Minimum RPM2000
Maximum RPM6200
Valve Float6500Cam
Timing:
TAPPET@.050Lift: Opens Closes Max lift Duration
Intake 4.0 BTDC 38.0 ABDC 107 222.0°
Exhaust 52.0 BBDC (2.0) BTDC 117 230.0°
Remarks:
Crane Cams continuously improves and upgrades its cam designs. In some cases this may mean that two Crane Cams with the same part number may actually be different grinds. You must check the GRIND NUMBER stamped on the front of the camshaft and check it against the Grind Number near the top of the Spec Card. For more information on the finest available camshafts, valve train components, and automotive ignition products, visit your local Crane dealer or call the Crane Cams tech line at (386) 258-6174 or FAX (386) 258-6167
Part Number:119831
Description
BASIC RPM 2500-6000
Cam Timing:
Part Number99838
Loads:
Open313LBS @1.150
Minimum RPM2000
Maximum RPM6200
Valve Float6500Cam
Timing:
Remarks:
