Will this throw a code? Will this give me a cooler running engine?
I plugged the vacuum line to the EGR to cure a missfire, she's running much better now.What harm am I doing and how do I take off the plenum to get to it ? Any help is greatly appreciated. Roger.As other people have commented, it is part of the total system. Don't delete it. Yes, people have deleted and they have no clue as to why, except "somebody" else did it. Seafoam / Deep Creep works great at removing carbon residue.
CG
I can tell you right know, that putting on a block off plate for your EGR will do next to nothing for performance. As the EGR only operates (for the most part) during cruising conditions ie. highway driving, etc...At WOT it will never be open, unless it has a problem with the EGR system.
Thanks Oz. Roger.
It threw a code 32 and on the way home it started to over heat. So I thought it would be easier and cheaper to block it off. Are corvette TPI egr's readily available in the auto parts stores or is this an order deal?
Hi Schrade, it DID cure the missfire. BUT. See my other thread. Thanks. Roger.Except the misfire isn't cured...
And the tank vapors will accumulate and find a way out somewhere. And we should probably mention that the vapors can burn a little bit YUP.
