C
cmegga
This may be a very dumb questoin, but I dont want to destroy anything.
I have an 81, Im trying to get the plastic seat buckets out to change the seat belts. On the bottom buckets closer to the back of the car, there are 2 bolts on each ( the larger bolts) I cant get any of them to budge. Even let them sit in wd40 for a day. what ever is under there I cant get to is spinning with the bolt. When I apply pressure I feel like the platic will shatter. I have already broke the medal surround that was rivited in.
Before I take the dremel to them, does anyone know if these bolts are replaceable after I cut them off. Or is this a special bracket under the bucket I will need to shell more cash to replace ?
Any thoughts or trick to getting these loose ??
