tdr1919 said:
Guys,
So, I want to replace the leaking valve cover gaskets. Is there any trick to getting these covers off without dis-asessembling the entire engine?
easy things first... I think a lot of people powder-coated their valve covers rather than painted them. Holds up better. If you have center-bolt covers (late 86) and a red exterior, then I have a set that I'll sell you cheap. They're not factory covers, but look good.
Now, to the difficult question. This, if I remember correctly, is how I removed my valve covers.
1. Loosen the pulley from the AIR pump on driver's side.
2. Take off accessory serpentine belt and remove the pulley. Then remove the long bolt that holds the AIR pump in place and goes through to where the valve cover is on the driver's side.
3. On driver's side, remove the spark plug wires (to get them out of the way, loosen the four bolts/nuts holding the cover, remove the PCV valve. You should now be able to pry/lift the cover out of the car.
4. On the passenger side, remove the breather tube from the valve cover. Remove the EGR pipe (the metal tube that crosses over the valve cover from the exhaust manifold to the intake manifold). You may be able to get by with just disconnecting it at the exhaust. Be forewarned, as Moonunit said, this is a bear to put back. Most people use a hose clamp instead of the factory clamp, which is easier.
5. Now remove the passenger valve cover.
6. Installation is reverse of removal
I personally like FEL-PRO's blue Perma-torque gaskets. They do not leak for anything when tightened right.
Also, if you have perimeter-bolt covers (iron heads), be aware that the bolts/studs/nuts get tightened to 20 INCH-LBS!!!! Too much tighter and you'll break a stud or crack a cover. Don't ask me how I know...
[RICHR]
