Wow some good A/C advise here
Finally some people who acutally speak AC.. great,
Rich.. I run F-12 in my 88 and my kids 91 camaro & the other ones 90 Honda.
This takes a bit less to charge the system that R-12 but don't worry about that.. they are different gasses.... my discharge at the vents is approx 34 degrees on ALL the cars at about 1500 rpm @ engine temp of ~ 200 with an outside ambient of over 80 degrees 30 % humidity...
It is a MUST to pull a vac on an open system I do an hour as a rule of thumb.
and NOW I always reseal every O ring and I visually inspect & CLEAN the expansion valve and or orifice tube ( that hosed me on my 92 EXPOLDER!)
I had to do the compressor twice due to a clogged orifice tube.. the high side doesn't like 320 psi.. and the front seal likes that less... let alone the clutch.
I ALWAYS change the drier ( it's like using an old oil filter ).
and the part most people miss....
pick all the rocks, bugs,paper bags & bird feathers out of the condenser.. straighten out the fins, wash it off with simple green ( LOW PRESSURE WATER ).Also make sure the front of the radiator is free of debris see my latest posting about that.
AND
remove the blower motor.. reach in & get all the YUCK off the evaporator.. and you will be as good as new.
Vig~
