PMartin
I replaced the E4ME carb last night with a rebuilt one i bought at international carburator. I have an issue when you get down on it the throttle wants to stick at around 3000rpm and you have to shut the key off to get it idle back down. Does anyone know if any adjustments that need to be done besides adjusting the idle? Also the check engine light is coming on again and giving me a m/c selinoid code 23 I think ( I had to ground the test terminal and use the check light method). I'm getting 11.7 volts at the selinoid. Any idea what i should to next?
Thanks,
P. Martin
Thanks,
P. Martin
