Replacing the Door
Estam
Michigan
This may come under Technical but can anyone tell me if is there is a plug and socket when replacing the door on a C4?
I am looking for a passenger side door and wonder if I'm going to have to splice the wires etc....
Thanks....
Hot Rod Roy
Mission Viejo CA
Yellow '84 Coupe
It's always a good idea to list the year of your C4 when you post. There are a lot of connectors inside the door, and the factory assembly process dictates that the car be easy to assemble, so you can be sure no splicing would be required to replace a door. I'm sure those connectors won't be the same from '84 to '96, so you'd probably be better off to get a door from the same year 'vette.
:w
Estam
Michigan
:w
Thanks Hot Rod, I have an 84 and have been told that the doors from 84 to 89 are basically the same so am hoping to get a pair later the better which might have some better hardware inside.
Hot Rod Roy
Mission Viejo CA
Yellow '84 Coupe
As you probably know by the info in my heading, I also have an '84. What's the problem with your doors? Replacing a door looks like a pretty major project!
:w
Estam
Michigan
:w
Backing too close to a 4x4 fence post completely ripped of my mirror. Mirror is perfect but it held on to much of the fiberglass skin and some rusty inside support frame still attached. Sent a picture to a friend and said I would be further ahead to get e used door. Figuring if the price is right I would replace both and hope for an updated winder mechanism. Would appreciate any thoughts...
