L
lheindrich
On my 75 The reverse lights do not come on when I put the car in reverse. I have an electrical diagram for the car but I have'nt done any electrical trouble shooting before so I am looking for some input before I start. The break lights and the turn signals function properly. There is a light green and a black wire on the diagram the lt green runs back to what looks like the fuse panel and a24A fuse, I am assuming the black wire is the ground but it also goes to a symbol that is a circle on the diagram marked with the#150 for the black and #130 for a tan wire that runs back to the fuse panel to a 30A fuse. Is this circle on the diagram the reverse switch? So does the switch have it's own fuse, and the bulbs have their own fuse I am a little confused. I guess I should first check for bad fuses, then for bad bulbs, then for loose wires, and last but not least a bad switch since this is the most expensive part. Any help would be greatly appreciated because I know the trouble shooting process is half the battle. Thanks, Lloyd.
