Ok. Going to take the plunge soon and try installing a set of roller rocker arms (the CAT stainless ones I asked about before). Reading through the Haynes, it doesn't seem like a huge job, but I do have some questions:
1. Is there a difference between moly-grease and lithium grease, such that I should try to dig up moly (molybdenum?)- based stuff? The Haynes says to use it.
2. The directions from CAT say to replace the pushrods at the same time I'm doing the arms. Is this just them assuming I'm doing a major buildup of the engine, or is it smart to replace the rods as well?
3. What about anything else in the valvetrain since I'm in there?
4. Anyone have a favorite method for assuring zero-lash of the pushrods?
5. If I'm installing a new rocker cover gasket, do I still need to use RTV? The Haynes wasn't clear.
5. Any gotchas I should watch for?
Thanks much...
[RICHR]
Thanks much...
[RICHR]
