Hib Halverson
If the car is recreational, why worry about 100,000 mi durability. If you drove the car 2000 pleasure miles a year it would take you 50 years to put 100K on it.
As for the Smog Check, that's an important issue because, with an 86, you're still in the program. I'm not sure, but I'm going to guess that California City is not in an area where the enhanced test is required. Am I right?
I can't tell your engine configuration will pass or fail, but I can say that camshafts with a lot of overlap and a rough idle are more likely to cause the engine to fail. This might be a problem for you because you want that rough idle.
My guess is that, to have a more aggressive camshaft yet still pass the smog check is going to require a high lift, short duration roller cam. You'll also need to keep your AIR pump and EGR.
