Check my logic please.
So I'm going to try nearly all of the suggestions that were given. In the event however that there does not appear to be an issue with my distributor, balancer, or timing chain. . .I think I'm back to too high of compression. Which means I have to work on reducing pressure.
I've done some research, and according to several publications, anything over 200 cranking psi is asking for trouble on premium pump gass. Anyone agree / disagree with that?
I previoisly reported that my cranking psi was 220. What I failed to remember at that time. . .was I was at 220 before I had my hardened valve seats done. . .which is when the heads were milled.
So I'm gussing that I'm actually over 220 at this point. So if I wanted to lower compression we talked about using a thicker head gasket, and that one company makes very thick gaskets at a high cost. So I may have a way out of this without having to buy new heads.
Now, obviously. . .I want to get closer to 200 psi or even lower if possible. I don't want to buy a new head gasket at high cost, only to find that I was way off on my guesstimate. . .and therefore blowing too much money on an expensive head gasket.
So I was thinking of the following test and wanted to run it by every one.
1) Test cranking pressure with engine cold
2) test cranking pressure with engine hot
3) calculate the % difference between the two numbers in order to detemrine the ~ cold cranking pressure equivelent from the hot number.
4) Pull one head off, and start stacking cheep head gaskets until I get a cold cranking pressure that equates to something close to 200psi hot using the percentage difference found in step three
It's important to note that I would never RUN the car with stacked stock gaskets. . .just used to determine cold cranking pressure. Would the gaskets seal well enough for this basic test?
I think this would allow me to get a ball park guess of what compressed thickness head gasket I would need to lower the psi to a number more in line with use of 93 pump gas.
Is this a reasonable approach to getting close to where I want to be in what I hope would be one expensive head gasket purchase?
