norwegianvette
My 1993 idles at 800 rpm when warm, is that to high. She idle nice, just high.
Manual or Automatic?
When switching off the heater the rpm drops. Is that normal? Anyone tried to put it on/off when ideling and have the same?
Steve
IAC should adjust the idle speed whenever the A/C is turned on/off but not the heater. Anytime the a/c compressor is running or turned off the idle should adjust itself.
Your idle RPM is the same as my 93. When the heater is on the air conditioner runs continuously to prevent fogging of the windows. This creates a heavy load demand on the alternator and so the ECM adjusts the fuel trim to maintain the current needed. This load demands so much hp that under hard acceleration the ECM automatically turns the air/heater off to improve wot performance.
I believe the rpm is a little higher when the ac/heater is on because the alternator needs to run at that speed to keep up with the electrical system load.
Could you disconnect the compressor clutch and run the heat? Like if your front compressor seal is leaking or if your compressor is on its way out, so you don't want the compressor running, but would like to have heat during the winter.
Actually the current practice of running the A/C compressor even with heat on was implemented for two reasons, as John mentioned it removes moisture from the air which helps keep windows clear. The second reason is that when A/C first came into common use the compressor would often sit idle for months at a time during the winter when owners needed heat, since an oil film contributes to the integrity of the front seal many cars would develop a leak there due to lack of compressor engagement until the manufacturers adopted the current practice.
