RPO codes for C4 Roof Panels
96CEVette
Atlanta, GA
I am looking at a 96 Vette that has two RPO codes for the top panels - one is 64s (removable panel - bronze tint) and the other is CC3 (removable plastic roof panel). I assume these are one in the same? I also see a code CF7 - ROOF,SUN,REMOVABLE,NON-TRANSPARENT REMOVABLE SUNROOF(CF7). So does that mean the car should have two tops with it?
Sorry, I am still in learning mode here, but thanks for any help.
I am looking at a 96 Vette that has two RPO codes for the top panels So does that mean the car should have two tops with it?.
Correct
should also have RPO C2L - Dual removable roof panels
CF7 - Non-transparent roof panel ( The std one fitted to car )
one is 64s and the other is CC3 . I assume these are one n the same?
CC3 identifies it came with the optional transparent roof
The XXS code identifies the color
CC3 - Transparent roof panel
64S - Bronze tint roof panel
24S - Blue tint roof panel
Correct
Much thanks for the response, that clears it up, and didn't realize the solid roof was standard.
If you ordered a car without a transparent top then the only code you would have is CF7
The RPO label reflects all the parts installed at the factory; not just the optional ones
