Rubber or Poly Bushing - How to tell?
Northern Virginia
71 Conv. (Sold) / 98 Pewter Coupe (Sold)
Rubber or Poly Bushing - How to tell the diff?
Good news: I found out my front end has been rebuilt fairly recently or at least it has all new bushings.
Bad news: The left upper bushing on the sway bar is split.
Question: How can you tell if it's rubber or polyurethane? I only have to replace the one bushing but I don't want to mix compounds.
Signed - Miffed in Manassas:L:L
Hi
Should be easy. Touch it, rubber feels like rubber.:D
Poly feels like hard plastic , will not give a bit.
You should already be able to see it from the split itself, the way it looks like.
Good luck
Gunther
Thanks Gunther! That means I have poly which would explain the somewhat harsh ride. I'll have one poly bushing please, hold the onions:L. Yes, I'm tired and feeling a little silly.
- Eric
