dshanks
Im in the middle of pulling my engine, hopefully to replace with a new one. Last night I pulled the a/c system, rad/core sup.
You know how it goes, you start taking things off, and you notice all kinds of additional issues that you hadn't planned on replacing. In my case, my budget is near spent on engine junk, anyway...
I noticed that almost all of the bushings and ball joints are original (71), most are trash. It needs to be done now, while its apart and accessible.
My question is, I know that poly is prefered, but at this point, I'm on a "superbudget". I noticed that I can get replacements at oreilly for WAY cheaper than buying rubber ones from yearone, ecklers etc.-much less poly...
I drive the car far less than 1000 miles per year, I dont race, and im very easy on the car. Will these cheaper rubber parts be sufficient? Are there certain bushings/parts that I should replace with poly for performance reasons, then settle for rubber for the rest?
(ex: use poly for this, this, and this. Use rubber for these cause it doesnt really matter...
or, rubber is preferred for these and these, because...)
Any help would be appreciated.
Derrick
Derrick
