Firestone Firehawk RF's...
Later . . . . . .
6 Shooter
...are the only way to fly!
:lol
:lol
Later . . . . . .
6 Shooter
:lol
Later . . . . . .
6 Shooter
mabye I am missing something here, but I don't find OEM tires rough riding, or bad handling. Oh well to each his own![]()
Well.........I have 12K on my orig run flats and I know in a year or two I will be at the cross roads looking to decide which way to go. I have no idea right now! I like the secure feeling of knowing the when I rob a bank and the law throws down a spike strip I can laugh as I keep going....hnoes(uhhh did I say that outloud?
) But also like hearing how the ride might be quieter and smoother with non run flats. I don't know I really dont. But I hope this thread goes on and on because it will be the one I look at again when I do reach the crossroads for sure!:W
AmenBottom line:
run flats=security
non run flats=improved performance
I am amazed at the fact that the run flat debate rages on so much on the internet. I have a few observations to share:
1. Its a Corvette, not a Cadillac. If you want a totally quiet ride then you should not have bought a Vette.
2. The car does almost 180 stock. I think OEM tires are more than adequate performers unless you are looking to drag or do something "stupid" in your Vette.
3. If you hit a corner at high speed and run over a bump (the so-called "bump steer") I don't care what kind of tire you are running, you will jump sideways.
4. The Z06 has non-run flats because it was not designed to be the Grand Tourer the Coupe and Vert were designed to be. Yes, it was designed with more performance in mind. Street racer, track car, etc. If you use your Vette for this type of driving, by all means use non-run flats. Most Vette owners (yes, most) don't wish to be on the side of the highway trying to plug a flat.
Bottom line, you are taking a chance when you drive a car with no spare, no tire changing equipment and no place to store a spare on anything other than run flat tires. I don't find OEMs to be noisy or rough riding because I make sure the tires are at the correct pressures.
Just my .02
I guess the only thing that can be said:--- If you find a run flat tire that is better than OEM and cheaper why not buy it.![]()
A softer sidewall, narrower design, and softer compound rubber will indeed give you a softer ride, but that does not make it "better" than OEM rubber.
The OEM tire is the only tire (IMHO, of course) that looks right on a Vette short of changing wheel and tire sizes which require a reprogram of the PCM so as not to create problems with the AH/TC. The Goodyear OEMs are a wider profile than any of the aftermarket replacements which (among other things) contributes to the "harsh ride" that they deliver on certain driving surfaces. A lot of owners exacerbate this expected (at least it should be expected) characteristic of the OEMs by running them longer than they should. The rubber is going to do what ALL tire rubber does when exposed to the elements for a long time, they are going to become hard as a rock, even if the tread is still good. Under normal driving, OEMs should be good for 15k to 25k miles before replacement, any more than that and you will have the "harsh ride", bump steer, and tramlining that everyone always talks about.
I really think the biggest problem that folks have with OEMs is the price. Folks come up with all kinds of excuses to go with cheaper tires. I am not talking about the die-hard modders that are looking for a performance edge. I grant you that the OEMs are NOT built to be run over and over again on a track or a drag strip. There ARE better tires for that kind of driving.
A properly maintained set of OEMs at the right pressures and changed every 15k-25k miles is all the average Vette driver needs. Its a sports car! Even a Ferrari give you a somewhat rough ride at times.
I like the 200 mile distance....sorryWell I guess there's nothing else to be said on this subject.
Remo:cool
BF Goodrich g-Force KDW-2's
