Sportsmiss
My right front running light keeps going out - I have it replaced and within 2 weeks it's not working again. All other lights work fine....any suggestions on the problem?
I jusy replaced the socket on the driver's side because it showed burn marks and continually quit working.
Dorman part # is 85882. It's a pretty easy fix by going into the access panel under the light. If you have small arms, you can reach in through the brake air duct and pull out the socket and rewire.
