Kid_Again
- Joined
- Jul 6, 2004
- Messages
- 1,171
- Location
- NJ - Which exit you from?
- Corvette
- 65 SB Roadster, 66 BB Coupe
I'm installing a Vortech supercharger on the '65 and will swap in new aluminum heads at the same time. I'll use moderate boost (8psi max) and would appreciate your recommendations on which gasket to use.
In addition, what's your adivce on the most appropriate heads to buy. The engine has the stock domed pistons and with my current Iron Eagle ~70cc heads, static cmpression is less than 9.5:1. My requirements are to keep the combustion chamber size in the ~70's range and get the largest valves possible. Intake runner length, I know is important so I would like to increase that into the 210/215cc class. I like the AFRs but they are 64cc heads. JEGS' entry level aluminum head looks pretty decent. Oh, I also need straight plugs but let me know if you think angled plugs will clear my hedman headers.
I'm going to aluminum to gain that extra protection against detonation.
