- Thread starter
- #41
Between the leaf's or leave's are rubber shims that are the same size as each leaf (length and width not thickness). I think that they arre also called leaf separators. They keep each leaf from rubbing with another leaf. Hench no squeak over big bumps or ass end squatting.Stallion said:What shims? Do you mean the actual leafs in the spring??
No, as already mentioned this is not only unsafe but also bad for car. Yes from personnal experience. I place mine on 4 stands (on frame) and started car. When I put it in gear and only at an idle let off the brake, holy S*** did it scare me to death. As mentioned the half shafts are not at propper alignment so the bolt locks, on the outer hub, go bang bang bang against something. I didn't let it run long enough to find out.Stallion said:Is this unsafe?: if I put her up on 4 stands today, can I get in her and start her? And actually get the rear wheels turning? And step on it pretty good? This will tell me if the problem is either suspension or drivetrain, right? But is that safe on 4 jack stands????
