F14JetJock
I've been changing out some of the screws and other fasteners on my car ( the fellow that owned the car before me, thought that if the hole was filled, it was good enough and even if the hole wasn't filled, that was OK too.). I've found metric hex head screws, screws holding the side pipe covers on that were just screwed through fiberglass and about 2 inches too long, bolts where screws should be and duct tape to hold parts together. Basically, anything and everything....except chewing gum and bailing wire.
Right now it is trial and error trying to swap out the fasteners with the correct screw / bolt. I have a copy of the "Corvette Assembly Manual" and it identifies the part as a "screw" or "bolt" along with it's part number.
Is there a source to decode the part number, referenced in the Assembly Manual, into the size the screw or bolt should be? ........ Sure would make the job easier than using Kentucky Windage.
