marteeni
How loud or noticeable is the sound of the vacuum pump running when the key is on with the engine off?? I've tried to listen for it several times and don't seem to hear it ruuning.
marteeni said:Actually, the inside looked really clean and the pump measured around 30 ohms (not shorted). The motor just wouldn't spin to operate the diaphram, like it was jammed up. Unfortunately, the diaphram linkage is encased in plastic, so I ordered a new one. I think it is interesting in what you said about the secondaries operating from the engine vacuum?? If that is the case, why bother with a seperate vacuum pump??
So what does this pump do? There is a vacuum reservoir located under the plenum. If the vacuum level in the reservoir drops below 41 kPa (12" Hg) while the secondary port throttle valves are open, the pump is turned "on" by a vacuum switch to supplement engine vacuum.
