Thanks for the info. Germany huh? How did a Vette end up way over there?
Yep, the tint is dark. But I'm Texas, and let me tell ya, it gets hot here, real hot. The dark tint helps.
1. My idel is high at start up/cold, goes right to about 1100 rpm. Same when it warms up and in drive. Stays about the same. I took her out last night. The temp was about 54 degrees, nice and cool out and it was the same.
I will check the things you talk about.
Vaccuum leak- where do I look for this? Coolant , u mean part of the radiator set up? I can check the screws. I put new air filters and sprayed the TBI with injector cleaner.
Also, do you think this is why it shifts hard from Park to R and D?
2. Gas gauge sending unit. I have heard of this. I can pull it right out from the top, where I put gas in? Should I disconnect my battery. That electric wire connector and gas, make me nervous?
Also have you ever had problems with your fuel pump or gas tank at all?
3. I will check for the antenna wires. I had a 97 trans am with electric antenna and the crappy thing went out in about 4 years. So I figured it was the little motor.
Glad I found a fellow CE owner. Sorry bout all the questions. Dang I wish you were state side, I could call ya....
Thanks,
R
I go away for a few hours and bang you guys are setting it down to 700 rpms already.. Good !
Germany: Well, it was bought in the States around 91 and shipped over to Germany, modded for Euro Spec and i bought it in 93. Moved to the States in 97, lived there for 10 and moved back in 2007. Poor thing has it's sealegs by now. :L
Let's make sure the idle is sorted first. But i did reply with a link to your PM re the Gas Tank Pump/Sender. It's tricky, but is possible. Gotta do the Twist.
IRS= Independent Rear Suspension.
I know when I try to move her during high idle, or, one time when my alternator was dead, so the choke wouldn't turn off and it was idling around 2,000 rpm, putting it in gear was like you were squatting down and launching hard. I really do think it's normal for right now, however if you get your idle fixed and it is still drastic, maybe you should look into some of the suspension pieces. I know there is a pad above the differential pumpkin that can wear out and causes this condition. One step at a time though.. idle first.
-Tatortot
Clunk is normal. I have it too. And the squat is part of the fun of the half shafts. If it's too bad, once all else is sorted, we'll look at that then.
OK Thanks. Took her out for spin for about 30 mins.
Still ideling about 700 ish, sorta sporadic. It still shifts hard into R and D from Park. I have not tried the PCV test yet. Will try tomorrow.
Maybe someone else can comment, but It sure seems to run cool.
The temp guage barely makes it to the second hash mark. Temps are in the 60's 2nite. I also noticed it has an electric fan mounted on the radiator in front of the mechanical fan. What is the factory thermostat?
Thanks,
R
Might be a good time to state the following:
Idle in P (COLD)
Idle in D (COLD)
Idle in P (WARM, ie. 165ish degrees, 2nd hash mark or above)
Idle in D (WARM, see above)
The temp gauge: Mine does it too, it takes a while to warm up. Once i sit in traffic for 5 minutes, bang the fans come on as it went over 180. Thats fairly normal though. Also, while it's 180+ it might shift 1-3, thats normal too, for emissions.
Running fairly cool is a good thing. Mostly these run hot and arent enjoyable then.
Re fans: Can you snap a pic, please?
Ask any questions, we're happy to help (as you can see above.
). And usually, i take the cake with dumb questions.
hnoes So dont worry about that.
-Stefan
