cash's90
After driving in traffic for several miles today, my tranny decided to stop shifting normally under a normal load. From a dead stop, it would not shift from low to second below about 3500 rpms and required about the same rpms to shift from second to third. It refused to go into OD. I tried shifting manually and it refused to upshift until the higher rpms were reached.
The tranny was rebuilt about 3 months ago and had operated flawlessly except for two widely seperated times when it seemed to hang up during the low to second shift and required higher than normal rpms to shift The tranny then seemed to operate fine.
After the car sat for a half hour or so today, I drove it around the block and it worked just fine with no apparent shifting problems.
Any ideas as to what to check first would be appreciated.
The tranny shop is a hundred miles away so I'd like to solve the problem locally.
