- Moderator
- #41
- Joined
- Nov 9, 2000
- Messages
- 7,556
- Location
- Edgerton, Ohio, United States
- Corvette
- 1959 black 270hp (9/2/69), 1981 Beige L81(10/20/80)
A total fire in the shop or house is my worst nightmare. It isn't so much the things that are lost that can be replaced but the things no amount of money can replace. Those may be tangible items or intangible like the many years spent building your business or restoring a car. I used to be a claims adjuster and I've worked many fires like this. Although it is terrible to have your own car damaged just think what your mechanic is going through. He lost his source of livelyhood on top of the loss of other's property that was intrusted to him.
The good news is that from every experience I have ever read about with Haggerty you will be taken care of in fine order. I just switched both Corvettes and my truck to Haggerty after researching these types of companies over the last couple of years.
As an aside, did you see the Hemi Coronet in Hot Rod last month? It was a clone but was under insured. The owner admits that he was lax in keeping the value of his car up tho date with Haggerty and it was no fault of Haggerty's. (Lesson to be learned here about reviewing your cars value annually.) Anyway, the building burnt and the fire departmant ended having a dozer push the smoldering debris up in a pile. The Coronet was in 3 pieces and was burnt to the ground. Things can always be worse.
Good luck on recovering your car safely. Don't take chances on any weak structure and be sure things are supported so nothing falls on anyone or the car.
Tom
Tom
)to all.
