Green LT1
I have a 1996 LT1 with 41,000 miles. It has never seen a race track, and is driven conservatively (most of the time). Every once in a while I will give it a little workout, but I never do burnouts. I have checked the ATF, and it looks and smells good as new. The transmission works flawlessly. The owners manual says it should not need to be changed for 100,000 miles under normal use. I have seen several threads indicating that the ATF should not be changed/flushed once the car has higher miles, as that can lead to transmission failure. That leads to my question - should I go ahead and change the ATF and filter now, as a preventative measure? Any thoughts on this would be appreciated. Thanks!
