slick 50?
mcditalia
central NJ
1966 convertible, 327 L79
I'm in the process of winterizing my car, and today I went to Pep Boys to buy motor oil. I was real tempted to buy a quart of slick 50 for $15 and add it with the rest of the oil.
Now I know there has been and endless debate about synthetics vs. conventional oil, so how about an oil additive for the c2's? Any insight? I am sticking with conventional oil right now, so I thought an additive like slick 50 might give a little extra protection.
Also, to change the topic a bit, I remember Johnz saying that he raises his tire pressure to 40psi for storage, I was under the impression that you reduce tire pressure for extended storage.
Thanks, MC
NO, NEVER!:puke
Sick 50
"slick 50"
Read your oil fill cap. If it says "oil", only pour oil through it.
If it says "pour any old sh*t in here", then Slick 50 is OK ;-)
40 psi in your tires for winter storage seems like a good idea. If you don't keep an eye on them, it will take them longer to go flat. Other than that it wouldn't make much difference.
I didn't even know it was still made, I haven't seen the latenight infomercial in so long.
Tom
I still use it from time to time.
It made a huge diference on a 85 Mustang cop car
I owned yrs ago. Had to idle it down about 100 rpm.
Had stock roller rocker and roller cam.
Maybe it freed things up? In any case, have never heard any bad reports on Slick-50 so I'm not sure what it could really hurt?
Its 1/2 the price as when it 1st came out.
Do a search about this stuff.
It has a history of making a meww in the engine.
It is a solid so it collects in the nooks and cranies.
Not sure but if the particles are big enough your filter will clog up when it "filters" this crap out of the oil so you could actual do more harm than good.
Not sure I understand why you want to use it to store your car for the winter ?? Just change the oil and put it away clean should be fine.
JMO as I did not stay at a Holiday Inn Express last night
Tom
You don't see their infomercials any more because "Slick 50" is under a consent decree from the Federal Trade Commission for fraudulent, deceptive, and false advertising practices which prohibits them from making any of the claims they used to make.
You don't need ANY additives in your oil - any brand-name oil that meets API specs has all the additives your engine needs in it already; the only benefit you'll see from additives is a lighter wallet.
You're all wrong. It's GREAT!
Every time I get more than a little constipated, I drink a couple of bottles of good ol Slick 50....Man oh man. You talk about cheese through a goose, Whew! It's a great product to free up some movement but it doesn't do much for my breath and since unlike me, my 65 roadster is not full of ****, I would never put it in the Vette.
Montana, Yeefreakinhaw!
The Slick 50 rep used to come around my father in law's trucking company. He used to tell the guy that the only thing slick about Slick 50 was the salesman. Threw a large wrench at him one day and he never came back. ;LOL
I agree that Slick 50 is not worth the risk of adding to a motor. First of all, I tried it in a Dodge Daytona Turbo Z 15 years ago and it didn't work. I added it twice -- as instructed. The first treatment was at 33k miles. The second was at 75k miles. Yet, my turbo went out at 87k miles! I can add that I did not drive this car particularly hard.
I've also seen studies that show the added protection doesn't help under normal circumstances. Additionally, there is a harmful additive that attacks your engine seals in exchange for the higher temperature breakdown. (I believe it was some form of Clorine).
I also talked to several oil reps and the consensus is the same. If you want to improve oil performance/protection in your car, synthetic oil is the only way to go.
Now that I have a Corvette, you won't catch me buying Slick 50 or a Chrysler again!
I tend to agrre with this!
XS650 said:
"slick 50"
I tend to agree with this statement! :L
Cheers
Tony
Try standing on your head and reading it. ;LOL
If you really want to protect your motor just use full syth oil and forget the slick 50 crap. All that PTFE stuff is just junk that is going to lead to increased wear. Syth oil stops all wear as soon as use start using it !
Sounds like the Slick 50 marketing guys are now working for the synthetic oil guys.
(Flame suit on) There is no substantiated independant proof that synthetic oil makes engines last longer than dino oil. The engines go 100K -150K miles with just about any type of oil in them, and when they do die, it's rarely from oil related wear. Synth oil make make your engine appear 'cleaner' inside, but that doesn't make it last longer.
Fire away!:r
My old Olds Ciera is sitting out there with 216k on the engine and it doesn't use any oil between changes. It has alwys been serviced at 3000 miles since new and not abused. Too bad it's collapsing from rust. Strickly dino juice.
I think the advantage to sythetics is reduced friction and resistance to higher temperatures. The temperature thing may not mean much in a street engine unless you loose a radiator hose on the interstate and aren't smart enough to kill the engine right away. As far as reduced friction leading to better fuel economy would you ever recover the extra cost of the oil in the time you owned your car?
Now for racing where even the smallest advantage is worth the cost it might be a different thing. plus the heat resistance would be an advantage.
Tom
Slick50 contains Teflon!
Now think about your kitchen pots and pans (Teflon coated) when new, they are great. But when you introduce them to heat and friction the Teflon breaks down and crumbles off. Would you scrape your pots and pans with a spatula and poor the remnants into the oil of your Corvette (I think not). Slick 50 does just this. Think about all the moving parts the oil in you car comes in contact with.
I hope this helps!!??
c5d said:
Less money, less time, less friction, added margin of safety on heat range....what could be better!
C'ya
D
The temperature lolerance seems to be the biggest reason. My understanding is that Chevy called out synthetic for the C4's so they could chintz out and not install an oil cooler.
Dick
25k WHAT ARE YOU THINKING?
I drive my Vette about 6K/yr. To leave oil in the motor for 4 years seems like a REALLY bad idea. I know that conventional oils break down in about a year but I don't know about synthetics. I would be reluctant to try it -- even if it were an acceptable interval.
Also, even if synthetic is better, the dirt is the killer. Carbon, dirt, etc. will always get into your oil. How much of this will accumulate during 25K miles!!!!!!!!!!!!
If I ran full synthetic, I would change at 3K just like conventional. At that rate, you would spend a lot more money on oil during the life of the car. Run the costs and see for yourself.
(snip)
(snip)
Sheesh. You guys gotta be smarter than this.
The oil filter traps that dirt.
Even if one chooses to use a premium synthetic and an extended drain interval, you still need to change the oil filter every 3000-5000 miles.
While I've used Red Line 10W30 with extended drain intervals for about the last ten years, under normal conditions, never have I run the oil more than 16,000-18,000 miles or for more than a couple of years. Under one-time test conditions, I ran RL 10W30 to 22,000 miles w. filter changes every 3000-4000 miles. Consumption in this test was 3000 miles per qt. After that test, spectrographic oil analysis indicated the oil had just about reached its life expectancy but was still servicable.
Anyone changing oil every 3000 miles is 1) living in the 1950s and 2) has been completely indoctrinated by the quick-lube oil change business' marketing B.S.
If you don't use a premium synthetic or don't care for extended drain intervals, my suggestion is to use at least the oil recommended for your car and change it at the recommended interval but....change the filter at half the interval. In the case of cars with oil life moniters, observe the moniter. It's even better than changing oil by mileage. On a C4s with oil life moniters, where the moniter does not read digitally, change the oil at half the oil change interval. On a c5, change the filter at 50% life.
As for Slick 50---that stuff is nothing but a marketing scam.
Years ago, DuPont tried to go to court to prevent the company which manufactures Slick 50 from marketing it for use in automotive engines. DuPont lost. Seems that, if the company that invented Teflon (the key ingrediant of Slick 50) feels it should not be used in internal combustion engines, then there's a problem somewhere.
As for Mobil One's marketing claiming it's been run to 100,000 miles with filter changes, know that Mobil 1 will not go anywhere near that far under normal conditions. However, put it in an engine that has high oil consumption, run the engine under lab test conditions and change the oil filter regularly and you'd be able to run 100,000 miles without an oil change----at least not an oil change where one removes the drain plug, drains the old oil out and puts new in. If you can find an engine that uses about a qt. every thousand miles or so, the oil you put in to replace oil consumed would keep the quality of the oil such that it could last 100,000 miles.
As for the record run and Morrison Motorsports use of Mobil 1 for setting that record. I was the only media present at that event. Yes, Tommy put Mobil 1 in that engine---heck, he was sponsored big-time by Mobil Oil back then, but remember, the engine that car only ran 5000 miles and, at that, ran most of the 5000 miles at engine speeds and loads quite a bit below the LT5's peak. That was not much of a test of oil.
Not to say that Mobil 1 a good product--on the contrary, it's a fairly good, synthesized hydrocarbon synthetic--but this is to bring a little reality to this thread.
