L
lanceh007
Hey everyone, I have something I hope you can help me with.
Over the past month, whenever I drive my car ('81 corvette) for about 20 minutes or longer, smoke starts billowing out of the left rear wheel well. It's very white, thick smoke and it looks like it's coming from the brake/caliper area. The caliper looks fine (as far as I can tell), it's not leaking any fluid and there is no residue anywhere. I've tried replacing the rotor and brake pads. I've also completely backed off the parking brake shoes (thinking that they might be sticking), so now I'm pretty sure that they can't even come into contact with the rotor hub (even with the parking brake fully engaged). So I don't think it's the parking brake causing this.
Today I took it down to the mechanic's shop and we used one of the laser temp gauges and found out that the left rear rotor was 115ºF while the right one was only 85ºF. So it seems like it's got to have something to do with the brakes, especially if that rotor is so much hotter.
Today I also jacked up the car and took off the rear wheels. I started it up and let it run in drive, allowing the rotor assembly to spin. I let it run for about 15 minutes that way, yet there was no smoke whatsoever, and the rotors felt the same temp. The brake caliper also looked like it completely released from the rotor (after pushing the brake pedal and releasing it), so I don't think the caliper is causing the pads to stick to the rotor...but who knows what it does with the wheels on? I just can't figure out what's going on...and I don't have any money left to take it to the mechanic (it's great being a poor college student!)
I was just hoping some of you might have some tips or ideas on what's going on and how I could fix this? Thanks!
Steve
