eoseitz
Hey everyone. I have kind of a strange issue. I have a 1974 Corvette that the prior owner had switched over to 4 wheel disk. I had the car sitting outside for a few weeks while I changed out my carpet. I finally got it back together and was going to take it out for the first time this year and noticed the brakes didn't feel right. They pretty much hit the floor. I checked the master cylinder and found the front compartment empty. The back one was still full of brake fluid. I assumed I hit a brake line while cutting a stuburn bolt off of my seat mounts. However, I haven't found any leaks. I noticed my gasket was shot in the master cylinder so I replaced it. The brakes still hit the floor. I've tried pumping them and get nothing. Could it be as simple as air in the lines from where my master cylinder went dry? I haven't pulled the tires yet, but from behind I didn't see any fluid leaking from the calipers. It just seems odd that last fall the master cylinder was full and now it's empty. Feels like a leak, but that's a lot of fluid to lose not to see any dripping anywhere. I believe the back disk breaks are off of an 80's model corvette.
