gmjunkie
Well,heres my way of thinking on the project!! But I'm no Rocket Scientist!!
But I use a thermal gun allot to see what individual cylinders are doing and yes to see exhaust temps from side to side and where the exhaust system is running the Hottest!! It has helped me determine restrictions in the exhaust systems!!
For Instance,THAT POS Ford Expedition of my son in-laws,(I won't Normally work on Fords,But I'm really not NORMAL anyway!!Just ask anybody that really knows me!!)
Anyway,Lee had taken it to Billy Mac's by the tracks,Precision Tune,and then to a Ford Dealer (They charged him about $950. Parts and Labor and determined that the cam was worn out!)and spent a Gaggle of $$$$ on it and it helped and ran better for a while!! It ran good cold,but the farther he drove it at higher speeds the worse it would run!! Finlay Chris loaded up Flo(The Grand Daughter!) and came up here for the weekend!! Saturday morning I put snappy on it and it was full of all sorts of codes including Random Miss-Fire 4,5,6,7,8,so I started looking things over and pulling coils,plugs,(1,2,3 plugs looked great#4 was Black and Sooty)(5,6,7,8 plugs looked lean as hell) compression tests between the cylinders was acceptable,Checked ohm-age on injectors and was fine(5.4 Ford you have to pull the fuel rails and 2 injectors on each side anyway to get the plugs out!!)I replaced #4 coil (Tested bad with Ohm Meter)and all the boots and put it back together!! Ran great,checked temps on exhaust and it was all purdy even!!Went for a ride to Spruce Pine and back, and on the way back it started Bucking,Popping,Farting,No Power and running Like the POS it is!!
Got home and got out the Thermal Gun and started sooting things!!(Wanted to use the Big Shiny 357!!) Rt Pre-Cat about 400 deg,Rt Cat about 490,Lt Pre-Cat about 500-550,Lt Cat about 850!! Cut that sucker off and stuck a piece of flex pipe in it and went for a drive and it ran like a Raped Ape even after 50 miles!!!Monday morning went to the parts store and got a universal cat and welded it in,and had her back home in Charlotte before she had to go to work at 5:30!! I told Chris that we needed to change the other side the next time she came up so it would have the exact back pressure!!
She said she would tell Lee,But if it was running right he'd never do nothing!!:bash:bash:bash
PS Never change plugs in a 5.4 Ford Truck!! They SUCK!!
Got home and got out the Thermal Gun and started sooting things!!(Wanted to use the Big Shiny 357!!) Rt Pre-Cat about 400 deg,Rt Cat about 490,Lt Pre-Cat about 500-550,Lt Cat about 850!! Cut that sucker off and stuck a piece of flex pipe in it and went for a drive and it ran like a Raped Ape even after 50 miles!!!Monday morning went to the parts store and got a universal cat and welded it in,and had her back home in Charlotte before she had to go to work at 5:30!! I told Chris that we needed to change the other side the next time she came up so it would have the exact back pressure!!PS Never change plugs in a 5.4 Ford Truck!! They SUCK!!
