JimBobC4
Tom94,
I have been watching this thread a while and see you have tried everything else. So here's my theory.
I think from what your describing you have a vacuum leak. Internal or external. It sounds like your getting air into the intake from an outside source.
If you give it a quick but spirited blip on the throttle ( in park at idle )
does the engine bog a little end then catch up so to speak ? Like the skip goes away after about 1k rpms ? a quick hard stab makes it bog but it slowly revs up fine ?
Maybe you have a bad intake gasket ?
The intakes are notorious for leaking.
Check the torque on the center bolts of the intake and see if those puppies spin out like they were hand tightened.
If so I would put some intake gaskets on it.
just a thought !
just a thought !
