A1Avette79
I have a '79, no Cruise Control, Auto. The Speedo stopped working. Took cable off at tranny and saw that the tip had sheared off. The last 1/8 in. of the cable was discolored as if it was heated. I have a new cable to install. I want to take the Driven Gear out to make sure it is OK and to make sure the missing tip from the old cable isn't still inside. I removed the retaining bolt (painted green for some reason) and the rectangular retaining washer. I can't get the gear sleeve out. I've pulled pretty hard but i didn't want to destroy something if i was doing it wrong. It's hard to get much leverage due to the cross member. @$%*!!!
ad
Is there anything else holding it in?
Second question. I am going to change my tranny filter (first start up in morning tranny delays about 2 seconds before engaging when shifting out of park). How much fluid will drain out when i drop the pan?
Thanks,
Trenton
adIs there anything else holding it in?
Thanks,
Trenton
