Ludigdrums
So, I've been trying to get my speedometer ('81) to read correctly with the new rims and tires, and calculated that I needed a 17 tooth driven gear and everything would be great. So I went to my local chevy dealer and got one ordered, although it wasn't listed.
So, I put it in, and it read exactly the same as the 20 tooth gear I replaced it with. It further deteriorated until it didn't work at all except for a slight little bump every once in a while.
So, yesterday, I removed the gear to see what was going on, and nothing looked wrong. I was able to spin the cable and see the speedo working. So, I know that the cables are fine, plus the transducer is a little over a year old. So, I reseated everything, and still nothing?
Can a 17 tooth gear not work with a 350 tranny?! The drive gear is blue.
But what I don't get is that it worked originally, although not reading correctly, and then died. I'm going to switch the 20 back in and see if it starts working again.
I want to get the speedo right, cause with the 20 tooth, it reads 10 MPH slow.
Thanks for any thoughts!
- Jeremy
- Jeremy
