Spider Gear setup specs needed
  • Thread starter Thread starter Daniel Becker
D
Daniel Becker
Hello,
I need the specs for setting up the spider gears in a 76. We are replacing the clutch pack and the new set is too tight with the current shims. Please respond if you have the info. Thank you,
Dan
Dan,
Try jimmybritts.com
His brother runs a shop called "Gears" and sets up the rear diffs for all of us in this local area. I have not seen one go bad yet.
