Question: Squeaking from A/C inside car
Matt99c5
San Antonio, Tx
1999, dark red c5 coupe
Right now every time I turn my A/C on, I get this very loud squeaking sound from the inside of the car. Before I would turn it off then on and the noise would be got not anymore, can't use A/C because of the noise.
Any ideas what is wrong and how can I fix it? Thanks
The blower motor in my 2000 coupe was very loud on initial start up. When I turned it off and on, the noise was gone for a while. It eventually got to the point it stayed noisy all the time. A new blower motor cured the problem. Hope this helps.
Only when the a/c is active? Or do you still get it with the fan running without a/c?
definitely inside and not under the hood?
This does help a lot, thank you very much, I'll check into the blower motor.
Yes the the noise is only when the I turn the a/c on. Yes it is inside. Thanks
