When driving slowly in a parkinng lot and going over bumps etc even w/ the windows up, AC on and radio at a modest or reasonable volume - I hear a very clear 'groaning' sound for the lack of a better description from the front end.
Best I can tell using a stethoscope and someone pushing down while parked - it 'seems' to be coming from the front sway bar bushings.
It's a 96 FE1 w/ 60k or so mi. It's stock and the front suspension other than lubing - the front end is stock, unchanged, from when it left the factory.
Q: Have others encountered moderately loud, noticeable noise from the front sway bar bushings?
Q: If not - what else should I suspect for the noise?
Q: What are some good techniques, lube etc that might quiet things down on a sustainned basis? The spray lubes I tried did very little and didn't last...
thanks
thanks
