littlejohn
New member
I really need anyone’s advise. I have a 04 Z06 and sometimes when I try to start my car the starter clicks, but the does not turn over. Sometimes, if I wait 15 min and try again, it starts. I can start it up ten times during the day (and drive it), no problem. Then all of a sudden the problem returns. Turn key, it clicks but motor doesn’t turn over. Or it will go a whole day and no problems at all. I took my car to Chevy and had them use the Tech II, there are no DIC codes showing up and all of my electrical accessories work fine. They even load tested my battery, it’s good.
I have a Sears Platinum (1 yr old) and it's fully charged. Batt terminals are clean and torque is correct. I've replaced my Theft Control Relay, Clutch Starter Switch and even cleaned the resistor on my key. Is it my starter, ignition module, or bad ground?
