R
RRROBB
my solenoid clicks and clicks continuously as long as key is turned. My starter does not turn over.......any suggestions??
Why you little ____!!!gmjunkie said:Yea What He Sezz!! And Put Some Tape On It!!gmjunkie!!
hit the case with a hammer and if the starters then spins the brushes have worn down and the springs do not have enought pressure to push then against the commutator and the blow with the hammer sometimes will cause the brushes to move.RRROBB said:my solenoid clicks and clicks continuously as long as key is turned. My starter does not turn over.......any suggestions??
