Help! Starts..Runs..Won't Re-Start
wilton
asheville, NC
'89 Black Sapphire
:W:W:W My '89 Coupe has left me stranded twice now :W:W:W
She'll start and run fine initially but after a few stops...she'll not re-start.
The engine spins but will not fire. After a period of time (doesn't matter how long...although a few hours helps) it will fire.
I replaced the fuel pump, it needed it, but that didn't help. It's throwing no codes, has fire and proper fuel pressure. ;shrug;shrug
Any ideas?
Thanks Guys
How old are the spark plugs? That would be my first place to look for trouble.
I'm not sure if your 89 has one, but I had the same issues on another vehicle and it turned out to be a bad ignition module........
I'm hittin' on about 1 cylinders lately on diags here on the boards, and I say leaking injectors.
How long did it hold 'proper' fuel pressure?
Any ideas?
Thanks Guys
Do you have a fuel pressure gauge? I would try and confirm that the injectors are not leaking down during hot soak.
The injectors were replaced last years w/new Bosch....
