ironmoo
As of the past few weeks on my '82, I've notice a bit more play in the steering wheel stem than before. This is in the area of the upper column where the signal posts/ steering adjustment post resides and slides into the lower column.. While the car is driveable, the play is about 1/2 inch from side to side or up and down when driving straight down the road while holding on the steering wheel. The lower portion of the column is rock solid and I've gone under the dash to make sure all the visable bolts/nuts are tight.
Looking closer, it really seems to be within the knuckle junction of the upper slides into the lower stem. Looking at the build manual, it's hard to tell if there are nuts,bolts,bearings, etc to tighten or work on from within the internal column.
Before I pull off the horn contact and steering wheel and jump in blindly to explore inside the upper column, I'd was hoping you all may have advise or your thoughts from your experience with the telescopic wheel.
Thanks in advance.
-Moo
Thanks in advance.
-Moo
