steering wheel/ turn signal
K
kelly ott
On a '65 with no power steering...... The turn signal stalk is broken. I removed the horn button, the wheel, and the nut and washer behind them. Now what? Do I need a steering wheel puller to remove the collar- brute force gets me nowhere. And what else is gonna be involved in this repair? Can't find a stalk in the Mid America catalog- is it still a GM number available at the dealer? If someone can walk me through this, then I'd appreciate it. The service manual shows many things for the steering system, but nothing as mundane as "stalk, turn signal, broken, repair and replace." Thanks
K
kelly ott
Is the large threaded bolt facing out where the center of the steering wheel puller's nose is gonna go? And will the collar come off of the bolt..... with the serrations letting go? And will wires be connected anywhere to this collar? And will this all just get tapped back on with a block of wood and a 10 pound sledge when finished? All info ahead of time appreciated.... no sense getting half way into this and learning the hard way. Thanks
K
kelly ott
All right, I'm ready to give it a try. Thanks for the input. If anybody has an idea on the part that I will be replacing- who has it, part number, etc.- please let me know.
K
kelly ott
The collar popped right off- wow, easy. The crescent- shaped white piece was broken right at the bolt connecting the signal arm. Removed the arm and reglued the piece... hope it works, as I have seen no listing for it in a couple of catalogs. Chime in, though, if a thought occurs- Thanks for the help, y'all.
V
Vettes Forever!
Directional Signal
I hope your fix works! However, if it doesn't it shouldn't be that difficult to find a new replacement directional switch: mine has been replaced several times over the years (I've had the car 38 years!). I'm not an expert in finding stuff, but have a friend that is. I'll be seeing him tomorrow on a club cruise and will ask him for sources.
BTW, this is a fairly common failure with the C2 'vettes. :hb
Save the wave! :beer
Fred
Tom Bryant
Administrator
Edgerton, Ohio, United States
1959 black 270hp (9/2/69) 1981 Beige L81(10/20/80)
That part that broke is the cancelling cam and used to be available seperately from GM. It was the same part number in that time frame across all GM car and truck lines. You might try your dealer since it is a common and popular part to replace. Would sure be a lot cheaper than a complete switch.
Did you mark the sreering wheel so you can put it back on in the same orientation as it was? If not, you might leave it loose until you are sure the wheels and steering wheel are straight before you tighten the nut again. Also check Paragon Reproductions and Volunteer Corvette found in the Portal under parts and accessories for this part.
Tom
Lucy64
South Riding, VA, USA
1964 Red Convertible and 2005 DSOM Z51 Coupe
Turn signal fix
I had the same piece broken off by my grandson about 2 years ago. I found all of the catalogs had the part and I compared the prices, called and found the one that had it in stock and shipped the quickest. It was around $70. Check Zip, Corvette Central and Mid America...they should all have the part. Good Luck.
Tom Bryant
Administrator
Welcome, Kerry,
Welcome to the Corvette Action Center.
Tom
